Introduction
Use this guide to replace the rear-facing camera flash in your Motorola Moto X.
Ce dont vous avez besoin
Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
Remove the SIM card tray.
Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
Slide the plastic opening tool along the seam toward the upper corner.
Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
Étape 11 Back Cover
Attention : l'étape 11 est issue d'un tutoriel marqué comme en cours.
Use the flat end of a spudger to gently pry between the flash assembly and back cover to separate the adhesive.
Remove the flash assembly from the back cover.
2 autres ont terminé cette réparation.
Un commentaire
Where did you buy the flash flex replacement?? I cannot find it.
