Aller au contenu principal
Motorola Moto X4 Screen Replacement
Ce dont vous avez besoin
  1. Motorola Moto X4 Screen Replacement, Heat the screen: étape 1, image 1 de 2 Motorola Moto X4 Screen Replacement, Heat the screen: étape 1, image 2 de 2
    • Before you begin, turn off your phone.
    • Heat an iOpener and apply it to the left edge of the phone for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take note of the the following areas:
    • Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
    • Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
  2. Motorola Moto X4 Screen Replacement, Create a gap: étape 2, image 1 de 3 Motorola Moto X4 Screen Replacement, Create a gap: étape 2, image 2 de 3 Motorola Moto X4 Screen Replacement, Create a gap: étape 2, image 3 de 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • Pull on the suction cup with strong, steady force to create a gap in the seam.
    • Insert the point of an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
  3. Motorola Moto X4 Screen Replacement, Slice the screen adhesive: étape 3, image 1 de 3 Motorola Moto X4 Screen Replacement, Slice the screen adhesive: étape 3, image 2 de 3 Motorola Moto X4 Screen Replacement, Slice the screen adhesive: étape 3, image 3 de 3
    • Slide the opening pick along the edge to slice through the adhesive.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Motorola Moto X4 Screen Replacement: étape 4, image 1 de 3 Motorola Moto X4 Screen Replacement: étape 4, image 2 de 3 Motorola Moto X4 Screen Replacement: étape 4, image 3 de 3
    • Heat the top edge of the phone with an iOpener.
    • Carefully slice around the corner and through the top edge to separate the adhesive.
  5. Motorola Moto X4 Screen Replacement: étape 5, image 1 de 3 Motorola Moto X4 Screen Replacement: étape 5, image 2 de 3 Motorola Moto X4 Screen Replacement: étape 5, image 3 de 3
    • Heat the screen's right edge with an iOpener.
    • Be careful not to slice too deeply near the cables to avoid damaging them.
    • Use an opening pick to slice along the right edge to separate the adhesive.
  6. Motorola Moto X4 Screen Replacement: étape 6, image 1 de 2 Motorola Moto X4 Screen Replacement: étape 6, image 2 de 2
    • Repeat the previous steps to heat and slice the bottom edge of the phone.
  7. Motorola Moto X4 Screen Replacement: étape 7, image 1 de 2 Motorola Moto X4 Screen Replacement: étape 7, image 2 de 2
    • Do not try to remove the screen yet—it is still attached to the phone by delicate flex cables.
    • Carefully lift up the left edge of the screen and cut away remaining adhesives with an opening pick.
  8. Motorola Moto X4 Screen Replacement: étape 8, image 1 de 1
    • Swing open the screen and prop it up with a small box as you work on disconnecting the flex cables.
    • During reassembly, this is a good time to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  9. Motorola Moto X4 Screen Replacement, Detach the fingerprint sensor cable: étape 9, image 1 de 2 Motorola Moto X4 Screen Replacement, Detach the fingerprint sensor cable: étape 9, image 2 de 2
    • Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
    • Do not pull on the cable. It is still attached to the phone by a delicate ZIF socket.
  10. Motorola Moto X4 Screen Replacement, Disconnect the fingerprint sensor: étape 10, image 1 de 3 Motorola Moto X4 Screen Replacement, Disconnect the fingerprint sensor: étape 10, image 2 de 3 Motorola Moto X4 Screen Replacement, Disconnect the fingerprint sensor: étape 10, image 3 de 3
    • Use the point of a spudger to flip up the lock bar on the fingerprint sensor's ZIF socket, near the bottom right of the phone.
    • Use tweezers to carefully slide the fingerprint sensor cable out of the socket.
  11. Motorola Moto X4 Screen Replacement, Disconnect the display cable: étape 11, image 1 de 3 Motorola Moto X4 Screen Replacement, Disconnect the display cable: étape 11, image 2 de 3 Motorola Moto X4 Screen Replacement, Disconnect the display cable: étape 11, image 3 de 3
    • Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
    • Use tweezers to carefully slide the display cable out of the ZIF socket.
  12. Motorola Moto X4 Screen Replacement, Remove the screen: étape 12, image 1 de 2 Motorola Moto X4 Screen Replacement, Remove the screen: étape 12, image 2 de 2
    • Remove the screen.
    • During reassembly, follow this guide to clean the existing adhesive off and install custom-cut adhesives for your phone.
  13. Motorola Moto X4 Screen Replacement, Heat the fingerprint sensor: étape 13, image 1 de 1
    • Apply a heated iOpener to the fingerprint sensor for one minute to soften the adhesive gasket.
  14. Motorola Moto X4 Screen Replacement, Loosen the fingerprint sensor: étape 14, image 1 de 2 Motorola Moto X4 Screen Replacement, Loosen the fingerprint sensor: étape 14, image 2 de 2
    • Slide the point of a spudger under the fingerprint sensor cable and gently pry to loosen the cable from the screen.
  15. Motorola Moto X4 Screen Replacement: étape 15, image 1 de 2 Motorola Moto X4 Screen Replacement: étape 15, image 2 de 2
    • Use an opening tool to pry up and loosen the fingerprint sensor from the screen.
  16. Motorola Moto X4 Screen Replacement, Remove the fingerprint sensor: étape 16, image 1 de 1
    • Remove the fingerprint sensor.
    • To reattach the fingerprint sensor, use a precut gasket, or apply some thin strips of Tesa adhesive to the perimeter of the sensor.
  17. Motorola Moto X4 Screen Replacement, Remove the earpiece grille: étape 17, image 1 de 3 Motorola Moto X4 Screen Replacement, Remove the earpiece grille: étape 17, image 2 de 3 Motorola Moto X4 Screen Replacement, Remove the earpiece grille: étape 17, image 3 de 3
    • If your replacement screen did not come with an earpiece speaker grille, you will have to transfer it from your original screen.
    • The earpiece speaker grille consists of two small mesh pieces. Be careful not to lose them as you transfer them over.
    • Use the flat edge of a spudger to push the grille from the front side of the screen to loosen it from its recess.
    • Remove the grille.
    • Use some thin strips of Tesa tape to affix the grille to the replacement screen.
  18. Motorola Moto X4 Screen Replacement, Remove the microphone gasket: étape 18, image 1 de 1
    • If your replacement part did not come with a lower microphone gasket, use tweezers to carefully peel it from your old screen and transfer it to your replacement part.
    • Compare your new replacement screen to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto X4 Answers community for help.
23 autres ont terminé cette réparation.
Arthur Shi
Membre depuis le 01/03/18
252 729 Réputation
526 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
8 commentaires
This guide really only covers screen removal, and should detail replacing the screen as advertised. Here are a few more steps that should be added:
1. Transferring old hardware to the new screen (seals, filters, fingerprint sensor, & the grey carbon mat.
2. Cleaning up old adhesive.
3. Applying new adhesive, whether it’s the one-piece that ifixit carries (recommended), or Tesa tape.
4. Installing the new display assembly
Andrew Parker - Réponse
Is it possible to remove and replace only the glass? Can I do that without removing the whole LCD screen and avoid disconnecting/reconnecting wires?
Drew S - Réponse
Hi Drew,
I haven’t tried, but I think it is possible to do a glass-only repair for this LCD screen, as long as you have the necessary tools and bonding adhesives. You would still have to deal with the fingerprint sensor, which is sealed onto the glass.
Arthur Shi -
I noticed the fingerprint sensor not being quite as low on the right edge after this. Also, I think it has a bit of “give” now when I press on it with a thumbnail. If the tips of my thumbs weren't so dry right now I might not have noticed, though.
Chris Young - Réponse
Hey Chris,
Did you add adhesive to the fingerprint sensor, if you didn't add some adhesive it may have some play, as most things need to be glued in place, and you could have forgotten to add some new adhesive.
Dominik Rodriguez -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 62
Total : 17,098
