Introduction
The modularity and easy to remove battery found in the Lenovo Moto Z earns it a 7 out of 10 on the repairability scale.
Pièces
Aucune pièce spécifiée.
External expansion is possible with magnetically attached "Moto Mods." Easily swapped external battery packs may increase life of device.
Sticky adhesive holds the display in place. Heat is required to soften the adhesive enough to pry up the display.
The display cable is long enough to allow you to fold the display over completely, so you don't have to support it while disconnecting.
However, it is very wide and hinders access to the battery connector—it's considerably easier to disconnect the battery after the screen is removed, which is not best practice.
The fingerprint sensor button and ambient light sensor are held onto the back of the display assembly with strong adhesive.
Heat was not needed, and both components can be easily reinstalled.
Battery has a plastic tab to aid in removal. The angle helps avoid ripping the tab off before it's free from the adhesive in the lower right corner.
Removing the adhered motherboard
Motherboard as a single component is an expensive repair, especially with the commonly failing charging port soldered on.
With the motherboard removed, the next layer of components can come out, including: front-facing camera, camera cover/LED flash assembly, heat pipe, button covers and switch ribbon cable.
The Lenovo Moto Z earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
Pull-tab on battery, easy to access once you have the device open.
Modular assembly allows independent replacement of many components
Display is adhered in place with no external fasteners, but the adhesive is weak enough to easily separate after heating.
Charging port soldered to the motherboard means a common repair will be very expensive.
Manufacturer does not provide user-accessible repair documentation.
28 autres ont terminé cette réparation.
10 commentaires
Is it possible to replace only the botoom part?
hi, do you have a wallpaper like the one on the iphone x so i can see the internals? thanks
Disculpen las guías no vienen en Español,? Gracias
