Introduction
Use this guide to replace the audio jack on your Motorola Z2 Play.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there's a good chance of accidentally damaging the display when removing it. If you intend to re-use the display, take serious care when heating and inserting tools to separate the display from the rest of the device.
Ce dont vous avez besoin
Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
Outil utilisé dans cette étape :Tweezers$4.99
Identify the ribbon cable, located at the bottom right of the phone.
If present, remove kapton (orange) tape covering the cable connector.
Flip up the small locking flap on the ZIF connector and use tweezers to slide the cable straight out of its socket.
Remove the seven silver 2.6 mm T3 Torx screws on the black battery cable cover at the bottom of the phone with a screwdriver by turning counterclockwise.
Remove the single black 3.5 mm T3 Torx screw on the black battery cable cover at the bottom of the phone with a screwdriver by turning counterclockwise.
Lift the battery cover with tweezers starting on the right side slightly to dislodge the cover.
Lift the battery cover with tweezers from the left side slightly to dislodge the cover.
Remove the battery cover with tweezers by solidly gripping the left side of the cover and lifting up.
