Aller au contenu principal
Introduction
Use this guide to remove or replace the screen on your Motorola Moto Z3 Play.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there's a good chance of accidentally damaging the display when removing it. If you're replacing the display anyway, then you don't have to worry—but if you intend to re-use the display, take serious care when heating and inserting tools to separate the display from the rest of the device.
  1. Power off your phone before you complete any replacement steps.
    • Power off your phone before you complete any replacement steps.
  2. Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
    • Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
    • If screen is cracked put strong adhesive tape across the screen in order to avoid breaking the screen further and receiving cuts.
    • If you don’t have access to a heat gun, a hair dryer can be used.
  3. Place suction cup in the middle of the screen and press down.
    • Place suction cup in the middle of the screen and press down.
  4. Pry the screen by wedging the plastic opening tool under the screen at the charging port. Work your way around the screen with the plastic opening tool. When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
    • Pry the screen by wedging the plastic opening tool under the screen at the charging port.
    • Work your way around the screen with the plastic opening tool.
    • When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
    • Complete these steps carefully because the screen is delicate and can easily crack. If the screen begins to resist prying, reheat the adhesive with your heat gun.
  5. Use a suction cup to lift up screen from left to right. If you don’t have a suction cup, wedge a spudger or a small plastic card under the screen and lift slowly. Failure to lift screen from left to right can cause damage to interior wires of your phone.
    • Use a suction cup to lift up screen from left to right.
    • If you don’t have a suction cup, wedge a spudger or a small plastic card under the screen and lift slowly.
    • Failure to lift screen from left to right can cause damage to interior wires of your phone.
  6. Identify ribbon connector at the top right of the phone. Pry the black locking bar up gently with a plastic opening tool. Remove the ribbon wires by pulling them out of the connector with a tweezer.
    • Identify ribbon connector at the top right of the phone.
    • Pry the black locking bar up gently with a plastic opening tool.
    • Remove the ribbon wires by pulling them out of the connector with a tweezer.
    • The locking bar is the small black bar located on the digitizer’s ZIF connector.
    • Be sure to push the locking bar back down using a spudger after you put the ribbon wire back in since the lock does not lock automatically.
  7. Identify the ribbon cable, located at the bottom right of the phone. Disconnect the ribbon cable, located at the bottom right of the phone, by pulling out and back with tweezers. Excessive force is not needed.
    • Identify the ribbon cable, located at the bottom right of the phone.
    • Disconnect the ribbon cable, located at the bottom right of the phone, by pulling out and back with tweezers.
    • Excessive force is not needed.
  8. Lift the screen from the phone to completely detach.
    • Lift the screen from the phone to completely detach.
    • If screen doesn't detach, go back to step 7 and 8 to make sure the bar is unlocked and ribbon connector is fully detached.
    • During reassembly, you may need to apply or replace the display adhesive on your display assembly. Use our display adhesive application guide to apply the adhesive and reseal your device.
  9. Apply an iOpener to the bottom edge of the display assembly for about a minute to loosen the adhesive beneath the fingerprint sensor.
    • Apply an iOpener to the bottom edge of the display assembly for about a minute to loosen the adhesive beneath the fingerprint sensor.
    • A heat gun may also be used, but take care to not heat one area of the display assembly for too long, as this could damage the display.
  10. Carefully pry off the fingerprint sensor by lifting it with the edge of an opening pick. Carefully pry off the fingerprint sensor by lifting it with the edge of an opening pick.
    • Carefully pry off the fingerprint sensor by lifting it with the edge of an opening pick.
  11. Remove the fingerprint sensor with a pair of tweezers.
    • Remove the fingerprint sensor with a pair of tweezers.
    • During reassembly, transfer the fingerprint sensor onto the new replacement display and press it into place.
    Thanks for the great guide. I had to use my low watt heat gun, sparingly. Also lots of glue to remove and then re-apply. Really good pictures helped.
    Kathleen Dombrowski - Réponse
Compare your new replacement part to the original part—you may need to transfer any remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Answers community for troubleshooting help.
26 autres ont terminé cette réparation.
mitch miller
Membre depuis le 24/01/2018
1 983 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team S19-G5, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S19-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G5
4 membres
22 tutoriels rédigés
9 commentaires
This is a guide for disassembly only. There are a few further steps required to replace front,,,
Jon Burgess - Réponse
The locking bar came completly off the phone. Is there a way to attach it back? I sure hope so or I’m screwed. Thanks
stang82gt - Réponse
nice man! i did this as well, i used paper card out of a deck of cards. works well BUT! look at where the cables run from your home botton/ fingerprint button and from you screen. i think i dammaged my home button by forcing my card pas the cable ripping it out of the motherboard.
chris - Réponse
Anyone have a link to a suitable stand alone fingerprint/home button adhesive? Maybe the adhesive pack sold here has it included but not sure. Ordered from another site and it wasn’t included. Can somebody confirm or provide another compatible adhesive/seal substitute?
eks1934 - Réponse
anyone else having a problem with the replacement screen not fitting? it seems like there is a bulge in the middle preventing the adhesive from keeping the screen attached to the frame on either side (top and bottom seals fine)
Jillie Pinkley - Réponse
I have the same problem with mine……does anyone have a solution , that doesn't involve buying another screen
kriscoupland1978 -
It is the battery ! Replace it before you assemble it. I made that mistake and it wasn't good. The battery swells with age as it wears out . It will keep the screen from being level and it will crack it .
Michael Cooper -
Completed a screen replacement, but I have the same problem mentioned above. The left side of the screen doesn’t want to stay down and attached. I’m suspecting maybe the battery is slightly swollen. Only way to know for sure is to take it back apart and try to replace the battery as well (high risk).
Jordan Grant - Réponse
Hi. I have a question. I have broken LCD on my MOTO Z2 play. Now I bought a new LCD and the LCD doesn´t work properly. Can be a problem with different model of LCD? The screen lights up but touching is not working? I noticed that there are different channels on the flex cable: Can be a different flex cable problem with working of touchscreen? Thanks for reply. David.
David Kucharcik - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 46
30 derniers jours : 182
Total : 17,820
