Aller au contenu principal
Motorola Photon 4G MB855 Headphone Jack Replacement
Ce dont vous avez besoin
  1. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Back Cover: étape 1, image 1 de 2 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Back Cover: étape 1, image 2 de 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Battery: étape 2, image 1 de 2 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Battery: étape 2, image 2 de 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: étape 3, image 1 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: étape 3, image 2 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: étape 4, image 1 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: étape 4, image 2 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: étape 4, image 3 de 3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Headphone Jack Replacement, Locating Headphone Jack: étape 5, image 1 de 1
    • Locate Headphone Jack attached to Midframe.
  6. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: étape 6, image 1 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: étape 6, image 2 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: étape 6, image 3 de 3
    • Use Tweezers to gently remove Headphone Jack from the Midframe.
    • The Headphone Jack is attached with adhesive, remove carefully.
Eddie Krause
Membre depuis le 10/07/14
260 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 8-6, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 346
