Aller au contenu principal
Motorola Q Global Display screen Replacement
Ce dont vous avez besoin
  1. Motorola Q Global Display screen Replacement, Battery: étape 1, image 1 de 1
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Display screen Replacement: étape 2, image 1 de 2 Motorola Q Global Display screen Replacement: étape 2, image 2 de 2
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Display screen Replacement, Display screen: étape 3, image 1 de 1
    • Press inwardly on the upper casing to release.
  4. Motorola Q Global Display screen Replacement: étape 4, image 1 de 1
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Display screen Replacement: étape 5, image 1 de 2 Motorola Q Global Display screen Replacement: étape 5, image 2 de 2
    • Remove the 6 screws using the T5 torx screwdriver.
  6. Motorola Q Global Display screen Replacement: étape 6, image 1 de 1
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Display screen Replacement: étape 7, image 1 de 2 Motorola Q Global Display screen Replacement: étape 7, image 2 de 2
    • Remove both screws on the mounted surface with a T5 screwdriver.
  8. Motorola Q Global Display screen Replacement: étape 8, image 1 de 2 Motorola Q Global Display screen Replacement: étape 8, image 2 de 2
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  9. Motorola Q Global Display screen Replacement: étape 9, image 1 de 2 Motorola Q Global Display screen Replacement: étape 9, image 2 de 2
    • Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit.
  10. Motorola Q Global Display screen Replacement: étape 10, image 1 de 2 Motorola Q Global Display screen Replacement: étape 10, image 2 de 2
    • Separate the front plate from the circuit board.
    • The LCD screen is attached to the circuit board by a thin ribbon.
    • Switch the lock on top of the circuit entry from horizontal to vertical.
  11. Motorola Q Global Display screen Replacement: étape 11, image 1 de 1
    • Insert the new LCD screen into the circuit.
Will Dickman
Membre depuis le 09/27/12
28 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-31, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 827
