Introduction
This guide requires the removal of various parts and screws so make sure you are in a clean and organized environment to prevent the loss of any components.
Ce dont vous avez besoin
Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
Remove the plastic yellow tape on the battery connector using the spudger.
Pry up on the orange connection to release it from the motherboard.
4 autres ont terminé cette réparation.
Un commentaire
so i have an old XT912 and i thought the other day it would be cool to have it running linux
however the device has a broken power button
actually no power button was too rough with it back in the when i had little knowledge about opening phones
the button is gone lol i remember using using a small screw driver to get it to respond a few times and it just stopped after a while
i think i dug it right off the board do you thinks its worth it to attempt to fix it or is there another way to get it to respond to power
>>>>>>>>>(-_//)
