Aller au contenu principal
Motorola RIZR Z3 Camera Replacement
Ce dont vous avez besoin
  1. Motorola RIZR Z3 Camera Replacement, Battery: étape 1, image 1 de 2 Motorola RIZR Z3 Camera Replacement, Battery: étape 1, image 2 de 2
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 Camera Replacement: étape 2, image 1 de 2 Motorola RIZR Z3 Camera Replacement: étape 2, image 2 de 2
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 Camera Replacement, Motherboard: étape 3, image 1 de 1
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 Camera Replacement: étape 4, image 1 de 2 Motorola RIZR Z3 Camera Replacement: étape 4, image 2 de 2
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 Camera Replacement: étape 5, image 1 de 1
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 Camera Replacement: étape 6, image 1 de 2 Motorola RIZR Z3 Camera Replacement: étape 6, image 2 de 2
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 Camera Replacement: étape 7, image 1 de 2 Motorola RIZR Z3 Camera Replacement: étape 7, image 2 de 2
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 Camera Replacement: étape 8, image 1 de 2 Motorola RIZR Z3 Camera Replacement: étape 8, image 2 de 2
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
  9. Motorola RIZR Z3 Camera Replacement, Camera: étape 9, image 1 de 1
    • Turn the phone to the front.
    • Push the keypad out through the plastic casing.
  10. Motorola RIZR Z3 Camera Replacement: étape 10, image 1 de 1
    • Turn the phone to the side.
    • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
  11. Motorola RIZR Z3 Camera Replacement: étape 11, image 1 de 1
    • Slip the plastic opening tool carefully between the camera and the plastic casing.
    • Gently pry the camera unit loose, being mindful of the adhesive that holds it in place and the copper colored ribbons that are attached to it.
Andrew Vu
Membre depuis le 10/07/11
35 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 5-34, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-34, Amido Fall 2011
CPSU-AMIDO-F11S5G34
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 650
