Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Guide to replacing a broken LCD.
  1. Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone. Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Tilt the battery by lifting at the exposed notch. Slide the battery out of its casing.
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Use a plastic opening tool to lift the plastic casing. Pull the plastic casing directly away from the phone.
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Lift the black rubber loudspeaker housing up and out of the plastic casing.
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  7. Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases. Caution: Remove carefully, if broken, the phone will not be able to make calls.
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  8. Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard. Caution: Remove carefully, if broken, the phone will not function properly.
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  9. Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out. Caution: Do this gently Unclipping too fast may cause damage to your phone.
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
  10. Turn the phone to the front.
    • Turn the phone to the front.
    • Push the keypad out through the plastic casing.
  11. Turn the phone to the side.
    • Turn the phone to the side.
    • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
  12. Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
    • Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
  13. Use a spudger to pry the plastic screen casing partially up from the LCD unit. Use the spudger to pry the ribbon cable away from its clip on the LCD unit. Caution: Do this carefully, damage to this ribbon cable will cause a blank screen.
    • Use a spudger to pry the plastic screen casing partially up from the LCD unit.
    • Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
    • Caution: Do this carefully, damage to this ribbon cable will cause a blank screen.
    • Pull the plastic screen casing directly away from the LCD unit.
  14. Use a spudger to lift the LCD partially away from the metal casing. Use the spudger to pry the ribbon cable directly up from its clip on the metal casing.
    • Use a spudger to lift the LCD partially away from the metal casing.
    • Use the spudger to pry the ribbon cable directly up from its clip on the metal casing.
    • Caution: Damage to the ribbon cable here will cause screen damage.
    • Pull the LCD completely away from the metal casing.
Brooke Shuford
Membre depuis le 10/10/2011
65 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-34, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-34, Amido Fall 2011
CPSU-AMIDO-F11S5G34
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 820
