Aller au contenu principal
Motorola Razr V3 Upper Casing Replacement
Ce dont vous avez besoin
  1. Motorola Razr V3 Upper Casing Replacement, Battery: étape 1, image 1 de 2 Motorola Razr V3 Upper Casing Replacement, Battery: étape 1, image 2 de 2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 Upper Casing Replacement: étape 2, image 1 de 2 Motorola Razr V3 Upper Casing Replacement: étape 2, image 2 de 2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 Upper Casing Replacement, Upper Casing: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to pry off the four rubber screw covers from the inside face.
    • Our phone is missing the two left screw covers, be careful not to lose yours too!
  4. Motorola Razr V3 Upper Casing Replacement: étape 4, image 1 de 1
    • Remove the four T5 Torx screws that were underneath the rubber covers.
  5. Motorola Razr V3 Upper Casing Replacement: étape 5, image 1 de 1
    • Use the plastic opening tool to pry the top cover away from the phone.
    • The side buttons on the phone may fall out when the top cover is separated from the phone. They can easily be put back by placing them in their original spot.
2 autres ont terminé cette réparation.
Ian Cottengim
Membre depuis le 04/18/13
172 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-46, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 27
Total : 3,198
