Introduction
This guide will show you how to remove and replace the camera for a Motorola V3c.
Pièces
Aucune pièce nécessaire.
  1. Remove the four rubber pieces from all corners of the area around the screen.
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
    • Pry screen cover off with plastic opening tool.
    • The screen cover has some adhesive holding it to the screen.
    • Remove small black sticker covering the camera ribbon connector.
    • Flip over small hinge that covers the camera ribbon connection.
    • Pull off the rubber camera cover and camera.
    • The camera and camera cover may come off either separately or together.
Ligne d'arrivée
Joshua Ruehlig
Membre depuis le 14/01/2010
503 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-4, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 4,380
