Aller au contenu principal
Motorola Razr V3c Lower Casing (CDMA) Replacement
Ce dont vous avez besoin
  1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): étape 1, image 1 de 3 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): étape 1, image 2 de 3 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): étape 1, image 3 de 3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Lower Casing (CDMA) Replacement: étape 2, image 1 de 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: étape 2, image 2 de 2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Lower Casing (CDMA) Replacement, Speaker (CDMA): étape 3, image 1 de 1
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Lower Casing (CDMA) Replacement: étape 4, image 1 de 1
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Lower Casing (CDMA) Replacement: étape 5, image 1 de 1
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Lower Casing (CDMA) Replacement: étape 6, image 1 de 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: étape 6, image 2 de 2
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Lower Casing (CDMA) Replacement: étape 7, image 1 de 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: étape 7, image 2 de 2
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Lower Casing (CDMA) Replacement: étape 8, image 1 de 1
    • Pull out the speaker.
  9. Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): étape 9, image 1 de 2 Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): étape 9, image 2 de 2
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
  10. Motorola Razr V3c Lower Casing (CDMA) Replacement, Lower Casing (CDMA): étape 10, image 1 de 1
    • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
  11. Motorola Razr V3c Lower Casing (CDMA) Replacement: étape 11, image 1 de 1
    • Pull off and replace the lower front casing
    • The metallic grounding grid will come off when the lower front casing is removed
    • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
krisko
Membre depuis le 01/14/10
104 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-4, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 6,233
