Introduction
This guide will show you how to remove and replace the screen for a Motorola V3c.
Pièces
Aucune pièce nécessaire.
Remove the four rubber pieces from all corners of the area that borders the screen.
  • Remove the four rubber pieces from all corners of the area that borders the screen.
Ajouter un commentaire
Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Be sure that you do not strip or damage the screws.
  • Carefully pry the screen away from the phone using a plastic spudger.
  • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
  • Take the screen housing off of the casing.
  • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  • Pry screen cover off with plastic spudger.
  • The screen cover has some adhesive holding it to the screen
  • Remove small black sticker covering the camera ribbon connector.
  • Flip over small hinge that covers the camera ribbon connection.
  • Pull off the rubber camera cover and camera.
  • The camera and camera cover may come off either separately or together.
  • Disconnect the metallic ribbon cover.
  • Remove and replace the screen.
Ligne d'arrivée
Joshua Ruehlig
Membre depuis le 14/01/2010
503 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-4, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 membres
8 tutoriels rédigés
Is it a T5 or a T4 for removing the screws?
Francis Reyes - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 8,946
