Introduction
This guide will help you replace the upper casing on your device. Following these steps will also enable you to replace the camera.
Pièces
Aucune pièce nécessaire.
  1. Remove the four rubber pieces from all corners of the area around the screen.
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
4 autre(s) ont terminé cette réparation.
krisko
Membre depuis le 14/01/2010
95 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-4, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 5,007
