Aller au contenu principal
Motorola SLVR L9 Antenna Cover Replacement
Ce dont vous avez besoin
  1. Motorola SLVR L9 Antenna Cover Replacement, Battery: étape 1, image 1 de 2 Motorola SLVR L9 Antenna Cover Replacement, Battery: étape 1, image 2 de 2
    • Turn the phone over so that the back of the phone is facing up.
  2. Motorola SLVR L9 Antenna Cover Replacement: étape 2, image 1 de 3 Motorola SLVR L9 Antenna Cover Replacement: étape 2, image 2 de 3 Motorola SLVR L9 Antenna Cover Replacement: étape 2, image 3 de 3
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Antenna Cover Replacement: étape 3, image 1 de 3 Motorola SLVR L9 Antenna Cover Replacement: étape 3, image 2 de 3 Motorola SLVR L9 Antenna Cover Replacement: étape 3, image 3 de 3
    • To remove the battery, pull the battery up from the bottom center.
  4. Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: étape 4, image 1 de 3 Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: étape 4, image 2 de 3 Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: étape 4, image 3 de 3
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
Eric Lopez
Membre depuis le 10/13/15
201 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 1-5, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-5, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 135
