Aller au contenu principal
Motorola SLVR L9 Camera Lens Cover Replacement
Ce dont vous avez besoin
  1. Motorola SLVR L9 Camera Lens Cover Replacement, Camera Lens Cover: étape 1, image 1 de 2 Motorola SLVR L9 Camera Lens Cover Replacement, Camera Lens Cover: étape 1, image 2 de 2
    • Turn the phone over so that the back of the phone is facing towards you.
  2. Motorola SLVR L9 Camera Lens Cover Replacement: étape 2, image 1 de 3 Motorola SLVR L9 Camera Lens Cover Replacement: étape 2, image 2 de 3 Motorola SLVR L9 Camera Lens Cover Replacement: étape 2, image 3 de 3
    • Press down on the battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Camera Lens Cover Replacement: étape 3, image 1 de 1
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
  4. Motorola SLVR L9 Camera Lens Cover Replacement: étape 4, image 1 de 2 Motorola SLVR L9 Camera Lens Cover Replacement: étape 4, image 2 de 2
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
Tayler Blanchard
Membre depuis le 10/13/15
258 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 1-5, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-5, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 181
