Aller au contenu principal
Motorola SLVR L9 Keypad Replacement
Ce dont vous avez besoin
  1. Motorola SLVR L9 Keypad Replacement, Battery: étape 1, image 1 de 2 Motorola SLVR L9 Keypad Replacement, Battery: étape 1, image 2 de 2
    • Turn the phone over so that the back of the phone is facing up.
  2. Motorola SLVR L9 Keypad Replacement: étape 2, image 1 de 3 Motorola SLVR L9 Keypad Replacement: étape 2, image 2 de 3 Motorola SLVR L9 Keypad Replacement: étape 2, image 3 de 3
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Keypad Replacement: étape 3, image 1 de 3 Motorola SLVR L9 Keypad Replacement: étape 3, image 2 de 3 Motorola SLVR L9 Keypad Replacement: étape 3, image 3 de 3
    • To remove the battery, pull the battery up from the bottom center.
  4. Motorola SLVR L9 Keypad Replacement, Camera Lens Cover: étape 4, image 1 de 2 Motorola SLVR L9 Keypad Replacement, Camera Lens Cover: étape 4, image 2 de 2
    • Turn the phone over so that the back of the phone is facing towards you.
  5. Motorola SLVR L9 Keypad Replacement: étape 5, image 1 de 3 Motorola SLVR L9 Keypad Replacement: étape 5, image 2 de 3 Motorola SLVR L9 Keypad Replacement: étape 5, image 3 de 3
    • Press down on the battery cover latch located at the top of the phone.
  6. Motorola SLVR L9 Keypad Replacement: étape 6, image 1 de 1
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
  7. Motorola SLVR L9 Keypad Replacement: étape 7, image 1 de 2 Motorola SLVR L9 Keypad Replacement: étape 7, image 2 de 2
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
  8. Motorola SLVR L9 Keypad Replacement, Antenna Cover: étape 8, image 1 de 3 Motorola SLVR L9 Keypad Replacement, Antenna Cover: étape 8, image 2 de 3 Motorola SLVR L9 Keypad Replacement, Antenna Cover: étape 8, image 3 de 3
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
  9. Motorola SLVR L9 Keypad Replacement, Keypad: étape 9, image 1 de 1
    • Use a screwdriver with a T6 Torx screwdriver head to remove both screws (1/8") from the speaker housing. Turn the screw counter-clockwise (left).
  10. Motorola SLVR L9 Keypad Replacement: étape 10, image 1 de 3 Motorola SLVR L9 Keypad Replacement: étape 10, image 2 de 3 Motorola SLVR L9 Keypad Replacement: étape 10, image 3 de 3
    • Using the grooves around the edge of the phone, gently pull the front plate away from the phone until it is fully removed from the device.
  11. Motorola SLVR L9 Keypad Replacement: étape 11, image 1 de 2 Motorola SLVR L9 Keypad Replacement: étape 11, image 2 de 2
    • Lift the keypad up from the front plate to remove.
Eric Lopez
Membre depuis le 10/13/15
201 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 1-5, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-5, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 346
