Introduction
The standby key is located at the top of the device and is used for resetting the device. It may fall out of place during disassembly of the device or through wear and tear. Use this guide to put the key back into place. Only realign the standby key once you are ready to reassemble and close the device. Otherwise it will fall back out of alignment.
Ce dont vous avez besoin
Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
Remove the screw and set aside.
Locate the two horizontal slots on the bottom of the device.
Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
Repeat with the other slot to completely unlock the device.
Grab the top and the bottom of the device and gently pull the device open.
Continue pulling until you have completely removed the top cover of the device.
Position the small black standby in the opening at the top of the case such that the wider teeth of the key is facing up.
Gently lower the key so the narrow teeth of the key are resting on the notch (circled in red) just below the opening at the top of the case.
Your standby key has been successfully realigned.
2 autres ont terminé cette réparation.
