Aller au contenu principal
Pièces
Aucune pièce spécifiée.
  1. Push down on the black tab located at the top center of the Motorola phone.
    • Push down on the black tab located at the top center of the Motorola phone.
  2. Remove the battery by pulling the battery from the top center.
    • Remove the battery by pulling the battery from the top center.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. Remove the four (4) T6 Torx screws from the back of the metal back plate.
    • Remove the four (4) T6 Torx screws from the back of the metal back plate.
  5. Insert the flat end of a spudger and pry the metal cover up off the phone. Insert the flat end of a spudger and pry the metal cover up off the phone.
    • Insert the flat end of a spudger and pry the metal cover up off the phone.
  6. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
  7. Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard. De-route the antenna cable by pulling it out.
    • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
Jorge Trujillo
Membre depuis le 19/05/2011
499 Réputation
4 tutoriels rédigés
Équipe
CSU Los Angeles, Team 1-1, Nelson Spring 2011 Membre de l'équipe CSU Los Angeles, Team 1-1, Nelson Spring 2011
CSULA-NELSON-S11S1G1
2 membres
4 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,735
