Introduction
Use this guide to replace the keypad.
  1. Push down on the black tab located at the top center of the Motorola phone
    • Push down on the black tab located at the top center of the Motorola phone
  2. Remove the battery by pulling the battery from the top center
    • Remove the battery by pulling the battery from the top center
  3. Remove the four (4) T6 Torx screws from the rear metal plate.
    • Remove the four (4) T6 Torx screws from the rear metal plate.
  4. Insert the flat end of a spudger and pry the metal cover up off the phone Insert the flat end of a spudger and pry the metal cover up off the phone
    • Insert the flat end of a spudger and pry the metal cover up off the phone
  5. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  6. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
  7. Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
  8. Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • The cover is attached by several clips, so some force may be required, especially to unclip the first clip.
    • Be careful not to loose the round plastic piece that covers the microphone.
  9. Remove the 2 newly exposed T6 screws Remove the 2 newly exposed T6 screws
    • Remove the 2 newly exposed T6 screws
  10. Starting at the top, insert the flat end of a spudger and pry the frame of the phone. The frame is attached by several clips, so some force may be required to dislodge the first clip.
    • Starting at the top, insert the flat end of a spudger and pry the frame of the phone.
    • The frame is attached by several clips, so some force may be required to dislodge the first clip.
    • Work your tool around the entire edge of the phone, moving as soon as you hear a clip come undone, to avoid breaking the frame.
  11. Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone. Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
    • Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
Jorge Trujillo
Membre depuis le 19/05/2011
499 Réputation
4 tutoriels rédigés
Équipe
CSU Los Angeles, Team 1-1, Nelson Spring 2011 Membre de l'équipe CSU Los Angeles, Team 1-1, Nelson Spring 2011
CSULA-NELSON-S11S1G1
2 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 5,322
