Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Use this guide to replace the keypad.
  1. Push down on the black tab located at the top center of the Motorola phone
    • Push down on the black tab located at the top center of the Motorola phone
  2. Remove the battery by pulling the battery from the top center
    • Remove the battery by pulling the battery from the top center
  3. Remove the four (4) T6 Torx screws from the rear metal plate.
    • Remove the four (4) T6 Torx screws from the rear metal plate.
  4. Insert the flat end of a spudger and pry the metal cover up off the phone Insert the flat end of a spudger and pry the metal cover up off the phone
    • Insert the flat end of a spudger and pry the metal cover up off the phone
  5. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
  7. Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
  8. Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • The cover is attached by several clips, so some force may be required, especially to unclip the first clip.
    • Be careful not to loose the round plastic piece that covers the microphone.
  9. Remove the two newly exposed T6 screws. Remove the two newly exposed T6 screws.
    • Remove the two newly exposed T6 screws.
  10. Starting at the top, insert the flat end of a spudger and pry the frame of the phone. The frame is attached by several clips, so some force may be required to dislodge the first clip.
    • Starting at the top, insert the flat end of a spudger and pry the frame of the phone.
    • The frame is attached by several clips, so some force may be required to dislodge the first clip.
    • Work your tool around the entire edge of the phone, moving as soon as you hear a clip come undone, to avoid breaking the frame.
  11. Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone. Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
    • Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
Jorge Trujillo
Membre depuis le 19/05/2011
499 Réputation
4 tutoriels rédigés
Équipe
CSU Los Angeles, Team 1-1, Nelson Spring 2011 Membre de l'équipe CSU Los Angeles, Team 1-1, Nelson Spring 2011
CSULA-NELSON-S11S1G1
2 membres
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 5,365
