Aller au contenu principal
Motorola V180 Motherboard Replacement
Ce dont vous avez besoin
  1. Motorola V180 Motherboard Replacement, Battery: étape 1, image 1 de 3 Motorola V180 Motherboard Replacement, Battery: étape 1, image 2 de 3 Motorola V180 Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
  2. Motorola V180 Motherboard Replacement, Motherboard: étape 2, image 1 de 3 Motorola V180 Motherboard Replacement, Motherboard: étape 2, image 2 de 3 Motorola V180 Motherboard Replacement, Motherboard: étape 2, image 3 de 3
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  3. Motorola V180 Motherboard Replacement: étape 3, image 1 de 2 Motorola V180 Motherboard Replacement: étape 3, image 2 de 2
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard by lifting it up out of the keypad.
Tyler Knisley
Membre depuis le 05/07/10
1 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 6-16, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 1,565
