Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Motorola V190 Keypad Replacement
Ce dont vous avez besoin
  1. Motorola V190 Keypad Replacement, Antenna: étape 1, image 1 de 2 Motorola V190 Keypad Replacement, Antenna: étape 1, image 2 de 2
    • Rotate the antenna counter-clockwise until the antenna is completely removed.
  2. Motorola V190 Keypad Replacement, Battery: étape 2, image 1 de 2 Motorola V190 Keypad Replacement, Battery: étape 2, image 2 de 2
    • Press the button at the bottom of the back cover.
    • Pull the back cover down.
    • Remove the battery.
    • Our device is missing the battery.
  3. Motorola V190 Keypad Replacement, Mini-USB Port/Motherboard: étape 3, image 1 de 1
    • Use the TR6 Torx Security Screwdriver to remove the four 6.3mm Torx screws on the back.
  4. Motorola V190 Keypad Replacement: étape 4, image 1 de 3 Motorola V190 Keypad Replacement: étape 4, image 2 de 3 Motorola V190 Keypad Replacement: étape 4, image 3 de 3
    • Use the iFixit opening tool to pry open the crevice at the top of phone.
    • Use the same tool to pry open the crevice at the bottom of the phone.
    • At this time, do not separate the ribbon from the motherboard at the bottom of the phone.
  5. Motorola V190 Keypad Replacement: étape 5, image 1 de 3 Motorola V190 Keypad Replacement: étape 5, image 2 de 3 Motorola V190 Keypad Replacement: étape 5, image 3 de 3
    • Remove the black rubber piece from the top of the motherboard.
    • Disconnect the rectangular ribbon from the motherboard.
    • Remove the motherboard.
  6. Motorola V190 Keypad Replacement, Keypad: étape 6, image 1 de 3 Motorola V190 Keypad Replacement, Keypad: étape 6, image 2 de 3 Motorola V190 Keypad Replacement, Keypad: étape 6, image 3 de 3
    • Reopen the phone.
    • Press the push buttons (the volume buttons) through the phone frame to fully remove the keypad.
    • Push the keypad through the keypad frame.
    • Remove the keypad by lifting it over the screw holes.
Michael Pollock
Membre depuis le 08/28/19
545 Réputation
5 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 47
Total : 479
