Aller au contenu principal
Motorola V276 Keypad Replacement
Ce dont vous avez besoin
  1. Motorola V276 Keypad Replacement, Battery: étape 1, image 1 de 1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Keypad Replacement: étape 2, image 1 de 1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Keypad Replacement: étape 3, image 1 de 2 Motorola V276 Keypad Replacement: étape 3, image 2 de 2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. Motorola V276 Keypad Replacement, Motherboard: étape 4, image 1 de 1
    • Use a spudger to remove the rubber plug from the upper left corner of the back of the phone.
  5. Motorola V276 Keypad Replacement: étape 5, image 1 de 1
    • Use a Torx T6 screwdriver to remove the 4 screws that secure the back plate of the phone.
  6. Motorola V276 Keypad Replacement: étape 6, image 1 de 3 Motorola V276 Keypad Replacement: étape 6, image 2 de 3 Motorola V276 Keypad Replacement: étape 6, image 3 de 3
    • Three tabs will hold the back plastic plate in.
    • To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  7. Motorola V276 Keypad Replacement: étape 7, image 1 de 3 Motorola V276 Keypad Replacement: étape 7, image 2 de 3 Motorola V276 Keypad Replacement: étape 7, image 3 de 3
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
  8. Motorola V276 Keypad Replacement: étape 8, image 1 de 1
    • Gently peel back the motherboard from the main part of the phone.
  9. Motorola V276 Keypad Replacement, Keypad: étape 9, image 1 de 1
    • Peel back keypad starting from the top of the phone
    • You can clean or replace the keypad once you have removed it from the phone
Ligne d'arrivée
Jonathan Cheung
Membre depuis le 04/11/10
1 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 27-96, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 847
