Aller au contenu principal
Motorola V276 Small LCD Display Screen Replacement
Ce dont vous avez besoin
  1. Motorola V276 Small LCD Display Screen Replacement, Front panel/ Screen Logic Board: étape 1, image 1 de 1
    • Using the plastic opening tool, pry off the top faceplate.
    • Place the tool in the small crack that runs along the side of the phone and pry.
  2. Motorola V276 Small LCD Display Screen Replacement: étape 2, image 1 de 1
    • Using the T6 Torx Screwdriver remove all 4 small screws.
  3. Motorola V276 Small LCD Display Screen Replacement: étape 3, image 1 de 1
    • Remove silver plate from phone.
  4. Motorola V276 Small LCD Display Screen Replacement: étape 4, image 1 de 1
    • Using the spudger remove the plastic camera casing
  5. Motorola V276 Small LCD Display Screen Replacement: étape 5, image 1 de 1
    • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
  6. Motorola V276 Small LCD Display Screen Replacement: étape 6, image 1 de 1
    • Use Spudger or hands to detach flex cable from front screen logic board
  7. Motorola V276 Small LCD Display Screen Replacement, Small LCD Display Screen: étape 7, image 1 de 1
    • Use a plastic opening tool to lift the small black flap to unlock the screen from the motherboard.
  8. Motorola V276 Small LCD Display Screen Replacement: étape 8, image 1 de 1
    • Using your fingers, carefully pull out the small LCD display screen.
  9. Motorola V276 Small LCD Display Screen Replacement: étape 9, image 1 de 1
    • Remove the small LCD display screen completely from the green logic board.
Cecilia
Membre depuis le 04/11/10
1 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 27-96, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 15
Total : 2,729
