Introduction
If you need to remove or replace the back case of your Motorola V557, follow this guide. You may need to do this repair if your back case has cracked or if you need to access the internal components of your phone.
Ce dont vous avez besoin
First, on the back of the phone find the silver button on the top left corner of the phone.
Simultaneously push down the button and slide the back plate down to reveal the battery.
Push the metal slider towards the top of the phone until it clicks out of the original position.
Gently slide out and remove the SIM card.
Grip the antenna and twist it counterclockwise to loosen it.
When it has been loosened all the way, pull gently to remove the antenna piece.
Using the push pin, gently pry the top two screws of the cover off.
The cover in the upper left of the back plate does not need to be removed.
