Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Step-by-step guide to replacing your phone's keypad buttons.
Pièces
Aucune pièce spécifiée.
  1. Flip the phone over to see back cover. Using either finger or spudger tool press button located  near the top of phone by the antenna.
    • Flip the phone over to see back cover.
    • Using either finger or spudger tool press button located near the top of phone by the antenna.
  2. Pry up back plate from phone to reveal battery. Push button near bottom of battery using either your finger of the spudger.  This will release the battery.
    • Pry up back plate from phone to reveal battery.
    • Push button near bottom of battery using either your finger of the spudger. This will release the battery.
  3. Using a T6 Torx Screwdriver, remove the four torx screws from the back of the phone.
    • Using a T6 Torx Screwdriver, remove the four torx screws from the back of the phone.
  4. Simultaneously press the highlighted buttons on both sides of phone. Simultaneously press the highlighted buttons on both sides of phone.
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Separate back plate from the rest of phone.
    • Separate back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Gently lift logic board from back plate.
    • Gently lift logic board from back plate.
  7. Place logic board on front cover. Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
  8. Once logic board is removed lift the green keypad sensor for the front plate. Once logic board is removed lift the green keypad sensor for the front plate.
    • Once logic board is removed lift the green keypad sensor for the front plate.
  9. To replace keypad buttons, lift off white tray containing buttons. To replace keypad buttons, lift off white tray containing buttons.
    • To replace keypad buttons, lift off white tray containing buttons.
Elizabeth OBrien
Membre depuis le 26/04/2010
31 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 30-40, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 membres
14 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,752
