Aller au contenu principal
Introduction
This guide shows how to take apart the front casing. This allows access to the front LCD screen.
Pièces
Aucune pièce spécifiée.
  1. Push in and hold small release latch.
    • Push in and hold small release latch.
    • Hold the latch through step 2.
  2. While holding the release latch, use a opening tool to help you slide off the front cover. While holding the release latch, use a opening tool to help you slide off the front cover. While holding the release latch, use a opening tool to help you slide off the front cover.
    • While holding the release latch, use a opening tool to help you slide off the front cover.
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Remove the two Philips screws at top of phone with a #1 Philips screwdriver. Remove the two Philips screws at top of phone with a #1 Philips screwdriver.
    • Remove the two Philips screws at top of phone with a #1 Philips screwdriver.
  5. Use a opening tool to gently pry off black cover, revealing the internal LCD display. Use a opening tool to gently pry off black cover, revealing the internal LCD display. Use a opening tool to gently pry off black cover, revealing the internal LCD display.
    • Use a opening tool to gently pry off black cover, revealing the internal LCD display.
Eric Freeman
Membre depuis le 26/01/2010
1 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 8-48, Regan Winter 2010 Membre de l'équipe Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 membres
13 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,178
