Aller au contenu principal
Motorola W315 Rear Case Replacement
Ce dont vous avez besoin
  1. Motorola W315 Rear Case Replacement, Battery: étape 1, image 1 de 1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Rear Case Replacement: étape 3, image 1 de 1
    • Insert the new battery.
  3. Motorola W315 Rear Case Replacement, Rear Case: étape 4, image 1 de 1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Rear Case Replacement: étape 5, image 1 de 3 Motorola W315 Rear Case Replacement: étape 5, image 2 de 3 Motorola W315 Rear Case Replacement: étape 5, image 3 de 3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Justin Scott
Membre depuis le 03/26/14
501 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 6-3, Benson Spring 2014 Membre de l'équipe Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 12
Total : 215
