Aller au contenu principal
Pièces
Aucune pièce spécifiée.
  1. Turn off the phone.
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  3. Insert the new battery.
    • Insert the new battery.
  4. Four 5 mm screws are visible (circled in red).
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  5. Insert the plastic opening tool between the front and back panels of the lower half of the device. Slide the tool around the entire frame of the device until it has loosened. Remove the back of the device.
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  6. Using back of the plastic opening tool, push the speaker out of the casing. Remove existing speaker. Replace with new speaker
    • Using back of the plastic opening tool, push the speaker out of the casing.
    • Remove existing speaker.
    • Replace with new speaker
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Jacob Gray
Membre depuis le 26/03/2014
401 Réputation
4 tutoriels rédigés
Équipe
Clemson, Team 6-3, Benson Spring 2014 Membre de l'équipe Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 membres
18 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 77
