Introduction
Is the plastic casing cracked or severely scratched? Replace it.
Ce dont vous avez besoin
Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center.
This might require a little persistence due how the beveled plastic rests on the phone body.
After the spudger is under the plastic piece, move counter clockwise using a gentle twisting motion until the piece is free from the phone body.
Hold the phone with the keys facing down and the mini USB charging port visible.
Open the rubber flap covering the charging port.
Insert the flat end of the spudger just above the charging port.
Using the same gentle twisting motion, work around the bottom of the phone and up the opposite side. The back casing should separate from the body of the phone.
