Aller au contenu principal
Motorola i1000plus Back Cover Replacement
Ce dont vous avez besoin
  1. Motorola i1000plus Back Cover Replacement, Battery: étape 1, image 1 de 3 Motorola i1000plus Back Cover Replacement, Battery: étape 1, image 2 de 3 Motorola i1000plus Back Cover Replacement, Battery: étape 1, image 3 de 3
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Back Cover Replacement, Antenna: étape 2, image 1 de 3 Motorola i1000plus Back Cover Replacement, Antenna: étape 2, image 2 de 3 Motorola i1000plus Back Cover Replacement, Antenna: étape 2, image 3 de 3
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Back Cover Replacement, Back Cover: étape 3, image 1 de 3 Motorola i1000plus Back Cover Replacement, Back Cover: étape 3, image 2 de 3 Motorola i1000plus Back Cover Replacement, Back Cover: étape 3, image 3 de 3
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Back Cover Replacement: étape 4, image 1 de 1
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Back Cover Replacement: étape 5, image 1 de 1
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Back Cover Replacement: étape 6, image 1 de 3 Motorola i1000plus Back Cover Replacement: étape 6, image 2 de 3 Motorola i1000plus Back Cover Replacement: étape 6, image 3 de 3
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
Austin Lake
Membre depuis le 10/18/13
501 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 13-3, Benson Fall 2013 Membre de l'équipe Clemson, Team 13-3, Benson Fall 2013
CLEM-BENSON-F13S13G3
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 187
