Introduction
Cell phone screens can easily be broken, but luckily, replacement is simple. This guide does not require any technical knowledge other than how to use a screwdriver. Any user should be able to replace their screen on this device.
Ce dont vous avez besoin
Push the tab located at the bottom of the battery towards the top of the phone.
Lift the battery away from the phone.
Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
Pull the antenna straight out of the phone.
Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
Using a spudger, pry the screen circuit board out of the front phone case.
