Introduction
As with all electronic devices, speakers will eventually stop functioning properly and need replacement. This guide will show the user how to replace the speaker in their device. This guide requires little to no technical knowledge and is easy to complete. Anyone should be able to follow this guide.
Ce dont vous avez besoin
Push the tab located at the bottom of the battery towards the top of the phone.
Lift the battery away from the phone.
Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
Pull the antenna straight out of the phone.
Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
Flip the motherboard over 180 degrees.
Place a spudger in between the gold plate and the bottom of the circuit board.
Carefully use the spudger as a prying tool to lift the circuit board from the motherboard.
Flip the keypad circuit board over to the other side to access the speaker.
Using the spudger, pry the speaker off of the circuit board.
