Introduction
The keypad protects the phone's interior while enabling the user to input commands into the phone.
Ce dont vous avez besoin
Place the phone on a flat surface with the front facing down.
Insert your finger under the gray plastic cover at the bottom end of the phone.
Lift the cover off the phone.
Place your thumb in the notch in the lower left corner of the battery compartment.
Lift the battery up and away from the phone.
Remove the battery.
Locate the metal slider that holds the SIM card in place.
Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
Gently lift the end of the circuit board farthest from the phone hinge.
Grasp the keypad at the bottom of the phone, raise it, and pull it away.
