Aller au contenu principal
Motorola i560 Metal Support Plate Replacement
Ce dont vous avez besoin
  1. Motorola i560 Metal Support Plate Replacement, Battery: étape 1, image 1 de 1
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Metal Support Plate Replacement: étape 2, image 1 de 1
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Metal Support Plate Replacement, Side Volume Button: étape 3, image 1 de 1
    • Pull antenna up, away from the phone, to reveal two of six screws.
  4. Motorola i560 Metal Support Plate Replacement: étape 4, image 1 de 1
    • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  5. Motorola i560 Metal Support Plate Replacement: étape 5, image 1 de 2 Motorola i560 Metal Support Plate Replacement: étape 5, image 2 de 2
    • Gently separate the front and back sides of the phone.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Metal Support Plate Replacement: étape 6, image 1 de 2 Motorola i560 Metal Support Plate Replacement: étape 6, image 2 de 2
    • Detach the first ribbon cable by unplugging it from the logic board.
  7. Motorola i560 Metal Support Plate Replacement: étape 7, image 1 de 3 Motorola i560 Metal Support Plate Replacement: étape 7, image 2 de 3 Motorola i560 Metal Support Plate Replacement: étape 7, image 3 de 3
    • Gently remove the side button by pulling the buttons away from the phone.
  8. Motorola i560 Metal Support Plate Replacement, Metal Support Plate: étape 8, image 1 de 3 Motorola i560 Metal Support Plate Replacement, Metal Support Plate: étape 8, image 2 de 3 Motorola i560 Metal Support Plate Replacement, Metal Support Plate: étape 8, image 3 de 3
    • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
Haley S
Membre depuis le 03/11/13
10 Réputation
4 tutoriels rédigés
Équipe
Clemson, Team 13-6, Benson Spring 2013 Membre de l'équipe Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 123
