Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Motorola i90c speaker replacement
Ce dont vous avez besoin
  1. Motorola i90c speaker replacement, Battery: étape 1, image 1 de 3 Motorola i90c speaker replacement, Battery: étape 1, image 2 de 3 Motorola i90c speaker replacement, Battery: étape 1, image 3 de 3
    • Slide the notch downward while pulling the back cover off to remove it.
    Demander à FixBot
  2. Motorola i90c speaker replacement: étape 2, image 1 de 3 Motorola i90c speaker replacement: étape 2, image 2 de 3 Motorola i90c speaker replacement: étape 2, image 3 de 3
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
    Demander à FixBot
  3. Motorola i90c speaker replacement, Antenna: étape 3, image 1 de 2 Motorola i90c speaker replacement, Antenna: étape 3, image 2 de 2
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
    Demander à FixBot
  4. Motorola i90c speaker replacement, Midframe: étape 4, image 1 de 3 Motorola i90c speaker replacement, Midframe: étape 4, image 2 de 3 Motorola i90c speaker replacement, Midframe: étape 4, image 3 de 3
    • Unscrew the 3 screws shown.
    • Lift the right part of the Nextel logo
    • Remove the screw underneath.
    Demander à FixBot
  5. Motorola i90c speaker replacement: étape 5, image 1 de 2 Motorola i90c speaker replacement: étape 5, image 2 de 2
    • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
    • Gently lift the back cover off.
    Demander à FixBot
  6. Motorola i90c speaker replacement: étape 6, image 1 de 3 Motorola i90c speaker replacement: étape 6, image 2 de 3 Motorola i90c speaker replacement: étape 6, image 3 de 3
    • Find the connection between the headphone jack and logic board.
    • Begin separating the two pieces, slowly and carefully.
    Demander à FixBot
  7. Motorola i90c speaker replacement, Speaker System: étape 7, image 1 de 3 Motorola i90c speaker replacement, Speaker System: étape 7, image 2 de 3 Motorola i90c speaker replacement, Speaker System: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    • Use the prying tools to wedge out the circular part of the speaker system.
    • Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers.
    Demander à FixBot
Jorge
Membre depuis le 04/14/10
4 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 29-61, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 61
Total : 1,424
