Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Motorola syn1654A Microphone Replacement
Ce dont vous avez besoin
  1. Motorola syn1654A Microphone Replacement, Microphone: étape 1, image 1 de 2 Motorola syn1654A Microphone Replacement, Microphone: étape 1, image 2 de 2
    • Remove star head screw from above base of the microphone with T6 Torx Screwdriver.
    • To prevent stripping, use an appropriate bit and ensure screwdriver is oriented perpendicular to the face of the screw.
  2. Motorola syn1654A Microphone Replacement: étape 2, image 1 de 1
    • To expose the next screw, peel foam cover from the base toward the end of microphone.
    • Remove screw with screwdriver and place in a safe location.
  3. Motorola syn1654A Microphone Replacement: étape 3, image 1 de 3 Motorola syn1654A Microphone Replacement: étape 3, image 2 de 3 Motorola syn1654A Microphone Replacement: étape 3, image 3 de 3
    • With Screws removed, remove the microphone from foam and plastic cover to be inspected.
    • If the microphone is corroded or wires are frayed, it must be replaced.
  4. Motorola syn1654A Microphone Replacement: étape 4, image 1 de 1
    • Clip both wires to remove defective microphone.
    • Be sure to clip as close to the base of the microphone as possible in order to have enough wire for the new microphone.
    • Align wires with corresponding pads on new microphone and solder in place.
    • For soldering, see the Ifixit soldering guide: Comment souder et dessouder des connexions
John Ware
Membre depuis le 02/24/14
325 Réputation
2 tutoriels rédigés
Équipe
Michigan Tech, Team 5-1, Lauer Spring 2014 Membre de l'équipe Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
2 membres
3 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 20
30 derniers jours : 33
Total : 584
