Aller au contenu principal
Motorola syn1654A Speaker Module Replacement
Ce dont vous avez besoin
  1. Motorola syn1654A Speaker Module Replacement, Speaker Module: étape 1, image 1 de 2 Motorola syn1654A Speaker Module Replacement, Speaker Module: étape 1, image 2 de 2
    • See the speaker replacement guide and follow steps 1 and 2.
  2. Motorola syn1654A Speaker Module Replacement: étape 2, image 1 de 1
    • Use the T6 torx screwdriver to remove the seven screws located around the headphone cover and place the screws in a safe place.
    • To avoid stripping screws, be sure to use the right drill bit oriented perpendicular to the face of the screw.
  3. Motorola syn1654A Speaker Module Replacement: étape 3, image 1 de 1
    • Carefully lift the speaker out of its housing while leaving all wires connected.
  4. Motorola syn1654A Speaker Module Replacement: étape 4, image 1 de 1
    • Lift the module out of the headphone cup, leaving all wires attached.
    • Clip the two wires circled in orange.
    • Now that the speaker is free set it aside.
    • Clip the two wires circled in yellow.
    • Replace speaker module and solder it to the two wires circled in orange.
    • Now solder the speaker wires (circled in yellow) back to the module.
    • For soldering see the ifixit soldering guide: Comment souder et dessouder des connexions
Ben
Membre depuis le 02/24/14
104 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team 5-1, Lauer Spring 2014 Membre de l'équipe Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
2 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 12
Total : 252
