Aller au contenu principal
Mpow MPBH063 Battery Replacement
Ce dont vous avez besoin
  1. Mpow MPBH063 Battery Replacement, Battery: étape 1, image 1 de 3 Mpow MPBH063 Battery Replacement, Battery: étape 1, image 2 de 3 Mpow MPBH063 Battery Replacement, Battery: étape 1, image 3 de 3
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
  2. Mpow MPBH063 Battery Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
  3. Mpow MPBH063 Battery Replacement: étape 3, image 1 de 1
    • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
    • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
    • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
  4. Mpow MPBH063 Battery Replacement: étape 4, image 1 de 1
    • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
To insert a new replacement battery and reassemble your device, follow these instructions in reverse order.
Lianna Cook
Membre depuis le 10/09/18
248 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team S15-G5, Blackburne Fall 2018 Membre de l'équipe Sam Houston State, Team S15-G5, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G5
3 membres
5 tutoriels rédigés
2 commentaires
Where can I find a replacement battery for this speaker?
Sean DuBois - Réponse
I’ve owned this speaker for ages and have never been able to use it to charge anything. Can someone tell me what sequence of button I have to press to get it to work as a power bank?
RJ En - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 4,335
