Aller au contenu principal
Mpow MPBH063 Daughterboard Replacement
Ce dont vous avez besoin
  1. Mpow MPBH063 Daughterboard Replacement, Daughterboard: étape 1, image 1 de 1
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
  2. Mpow MPBH063 Daughterboard Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
  3. Mpow MPBH063 Daughterboard Replacement: étape 3, image 1 de 1
    • Unplug the wire connected to the daughterboard.
  4. Mpow MPBH063 Daughterboard Replacement: étape 4, image 1 de 1
    • Remove the silver 10 mm screw from the center of the daughterboard.
  5. Mpow MPBH063 Daughterboard Replacement: étape 5, image 1 de 2 Mpow MPBH063 Daughterboard Replacement: étape 5, image 2 de 2
    • Remove the daughterboard by carefully lifting the daughterboard out of the speaker with the metal spudger.
    • Use iFixit adhesive remover as directed
    • Before you remove the daughterboard, cut around the edges using the tech knife, and remove the adhesive securing the daughterboard to the speaker.
Jazely Barrera
Membre depuis le 10/09/18
121 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team S15-G5, Blackburne Fall 2018 Membre de l'équipe Sam Houston State, Team S15-G5, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 165
