Aller au contenu principal
Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement
Ce dont vous avez besoin
  1. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement, Thermal Fuse: étape 1, image 1 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement, Thermal Fuse: étape 1, image 2 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement, Thermal Fuse: étape 1, image 3 de 3
    • Remove the coffee pot.
    • Flip the Mr. Coffee machine over so the base is facing up.
  2. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 2, image 1 de 2 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 2, image 2 de 2
    • Use the Y1 Tri-point screwdriver to remove the three 1.5 cm screws from the baseplate.
  3. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 3, image 1 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 3, image 2 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 3, image 3 de 3
    • Use a flathead screwdriver to unclip the two clips from the back of the baseplate.
    • Unsnap the front clips and remove the baseplate.
  4. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 4, image 1 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 4, image 2 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 4, image 3 de 3
    • Use a Phillips screwdriver to remove the two 1.5 cm screws on the metal bracket.
  5. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 5, image 1 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 5, image 2 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 5, image 3 de 3
    • Rotate the Mr. Coffee machine around so the front is facing you.
  6. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 6, image 1 de 1
    • Locate the two thermal fuses.
    • The thermal fuses are attached to two different mounts and to each other.
  7. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 7, image 1 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 7, image 2 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 7, image 3 de 3
    • Clip each fuse where it connects with its mount with wire cutters.
    • Discard the fuses.
  8. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 8, image 1 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 8, image 2 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Do not touch the hot soldering iron. Use in a well ventilated area.
    • Hold the tail of the fuse with tweezers at the contact point from the previous fuse.
    • Avoid contact with soldering iron and other internal components.
    • Melt the solder material with the soldering iron at the point of contact until it melts and beads onto the tail of the fuse.
    • Hold the head of the new fuse with the tweezers at the contact point from the removed fuse.
    • Melt the solder material with the soldering iron at the point of contact until it melts and beads onto the head of the fuse.
    • While touching the wires of the fuses together, melt the soldering material with the soldering iron until it melts and beads onto the two wires.
  9. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 9, image 1 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 9, image 2 de 3 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 9, image 3 de 3
    • Place the support beam back into the original place.
    • Use a Phillips #1 screwdriver to fasten the 1.5 cm screws into place on the metal bracket.
    • The screws can be distinguished by looking at the head type. The two Phillips screws are for the metal support beam on the inside. The three tri-point head type screws are for securing the baseplate on the outside.
  10. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 10, image 1 de 1
    • Clip baseplate back into place by snapping the front into the clips first and then the back clips (by the cord).
  11. Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 11, image 1 de 2 Mr. Coffee 5-Cup Mini Brew Thermal Fuse Replacement: étape 11, image 2 de 2
    • Use a Y1 Tri-point screwdriver to fasten the three 1.5 cm screws into place on the baseplate.
Ligne d'arrivée
Megan Wood
Membre depuis le 01/22/24
193 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-3, Morris Winter 2024 Membre de l'équipe UC Davis, Team 1-3, Morris Winter 2024
UCD-MORRIS-W24S1G3
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 57
Total : 199
