Introduction
There are two O-rings in the Mr. Coffee BVMC-SJX33GT; If your coffee maker is leaking, the O-rings may potentially be damaged in some way and in need of replacement.
Make sure your coffee maker is unplugged and empty of all water before attempting to make any repairs.
Ce dont vous avez besoin
Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
Locate the metal clamps.
Using a pair of pliers or your fingers, slide clamps away from tube opening.
Locate the two 17mm screws securing the bracing bar.
Unscrew the screws with a #2 Phillip's head screwdriver and remove the bracing bar
Locate the five 11.5mm screws securing the plastic ring to the coffee maker.
Unscrew the screws using a #2 Phillip's head screwdriver.
