Aller au contenu principal
Mr. Coffee BVMC-SJX33GT Power Cord Replacement
Ce dont vous avez besoin
  1. Mr. Coffee BVMC-SJX33GT Power Cord Replacement, Base: étape 1, image 1 de 1
    • Turn your coffee maker over so that the base is facing up.
  2. Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 2, image 1 de 2 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 2, image 2 de 2
    • Locate the seven 13.5mm screws securing the base to the coffee maker.
    • Unscrew the screws using a #2 Phillips head screwdriver.
    • Use a screwdriver with a magnetic tip to more easily remove the three screws in the back and two in the middle.
  3. Mr. Coffee BVMC-SJX33GT Power Cord Replacement, security screws: étape 3, image 1 de 1
    • Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
  4. Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 4, image 1 de 1
    • Lift base to remove.
    • If the base sticks along one edge, do not pull at an angle. Gently tug straight up while sliding a finger along the edge in order to pop the clips.
  5. Mr. Coffee BVMC-SJX33GT Power Cord Replacement, Rubber Hose: étape 5, image 1 de 3 Mr. Coffee BVMC-SJX33GT Power Cord Replacement, Rubber Hose: étape 5, image 2 de 3 Mr. Coffee BVMC-SJX33GT Power Cord Replacement, Rubber Hose: étape 5, image 3 de 3
    • Locate the metal clamps.
    • Using a pair of pliers or your fingers, slide clamps away from tube opening.
    • All following steps regarding the rubber hoses should be completed for both hoses.
  6. Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 6, image 1 de 3 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 6, image 2 de 3 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 6, image 3 de 3
    • Using a plastic opening tool, loosen rubber hose from metal tubing.
    • Once loosened, grip the hose and pull it from the metal tubing.
  7. Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 7, image 1 de 2 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 7, image 2 de 2
    • Slide metal clamps off hoses.
  8. Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 8, image 1 de 2 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 8, image 2 de 2
    • Locate the other set of metal clamps.
    • Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
  9. Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 9, image 1 de 2 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 9, image 2 de 2
    • Grip the hoses and pull them straight up and out.
  10. Mr. Coffee BVMC-SJX33GT Power Cord Replacement, Power Cord: étape 10, image 1 de 2 Mr. Coffee BVMC-SJX33GT Power Cord Replacement, Power Cord: étape 10, image 2 de 2
    • Locate the two 11.5mm screws securing the plastic bracket in place.
    • Unscrew the screws using a #2 Phillip's head screwdriver and remove the bracket.
  11. Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 11, image 1 de 3 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 11, image 2 de 3 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 11, image 3 de 3
    • Locate the 11.5mm screw below the white, red, and blue wires. The screw is along the side of the coffee maker about four inches deep from the edge of the base.
    • Unscrew the screw with a #2 Phillip's head screwdriver and remove.
    • Using a screwdriver with a magnetic tip will allow you to remove the screw more easily.
  12. Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 12, image 1 de 2 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 12, image 2 de 2
    • Grip the connector box and pull it into view.
  13. Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 13, image 1 de 3 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 13, image 2 de 3 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 13, image 3 de 3
    • While maintaining a firm grip on the connector box, use needle nose pliers to pull the black wires free from the box.
    • Only place your pliers on the metal part of the connector, NOT the partially exposed wire.
    • Pull the connector straight out. If you pull at an angle, you risk breaking the connector or other components connected to it.The connector will stay attached to the electrical component of the coffee maker as indicated by the red box in the second photo.
  14. Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 14, image 1 de 3 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 14, image 2 de 3 Mr. Coffee BVMC-SJX33GT Power Cord Replacement: étape 14, image 3 de 3
    • Turn coffee maker around so that the back is facing you.
    • Pull the cord out through the back window.
Mackenzie Aiken
Membre depuis le 01/27/15
1 500 Réputation
6 tutoriels rédigés
Équipe
San Diego State, Team 1-4, Sheppard Winter 2015 Membre de l'équipe San Diego State, Team 1-4, Sheppard Winter 2015
SDSU-SHEPPARD-W15S1G4
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 36
Total : 3,208
