Introduction
If your coffee maker is experiencing power issues, you may have a faulty power cord. Use this guide to replace the damaged power cord of your Mr. Coffee BVMC-SJX33GT.
Make sure your coffee maker is unplugged and empty of all water before attempting to make any repairs.
Ce dont vous avez besoin
Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
Locate the metal clamps.
Using a pair of pliers or your fingers, slide clamps away from tube opening.
Locate the two 11.5mm screws securing the plastic bracket in place.
Unscrew the screws using a #2 Phillip's head screwdriver and remove the bracket.
