Aller au contenu principal
Mr. Coffee DRX5 Warming Plate Replacement
Ce dont vous avez besoin
  1. Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: étape 1, image 1 de 3 Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: étape 1, image 2 de 3 Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: étape 1, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
  2. Mr. Coffee DRX5 Warming Plate Replacement: étape 2, image 1 de 1
    • Slide display out of the way.
  3. Mr. Coffee DRX5 Warming Plate Replacement: étape 3, image 1 de 3 Mr. Coffee DRX5 Warming Plate Replacement: étape 3, image 2 de 3 Mr. Coffee DRX5 Warming Plate Replacement: étape 3, image 3 de 3
    • Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
  4. Mr. Coffee DRX5 Warming Plate Replacement: étape 4, image 1 de 1
    • Pull heating element out of the way.
  5. Mr. Coffee DRX5 Warming Plate Replacement: étape 5, image 1 de 1
    • Twist warming plate clockwise so that the tab is out of place. Remove warming plate.
Michael Chhim
Membre depuis le 03/21/17
205 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G2, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S2-G2, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G2
3 membres
5 tutoriels rédigés
Un commentaire
Interesting that you can take the thing apart, do nothing else but put it back together again, and it’s supposed to be fixed? What about the step of replacing the broken part? I don’t see mention of that.
destravlr - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 608
