Aller au contenu principal
Mr. Coffee DRX5 Water Reservoir Replacement
Ce dont vous avez besoin
  1. Mr. Coffee DRX5 Water Reservoir Replacement, Water Reservoir: étape 1, image 1 de 3 Mr. Coffee DRX5 Water Reservoir Replacement, Water Reservoir: étape 1, image 2 de 3 Mr. Coffee DRX5 Water Reservoir Replacement, Water Reservoir: étape 1, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
  2. Mr. Coffee DRX5 Water Reservoir Replacement: étape 2, image 1 de 3 Mr. Coffee DRX5 Water Reservoir Replacement: étape 2, image 2 de 3 Mr. Coffee DRX5 Water Reservoir Replacement: étape 2, image 3 de 3
    • Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
  3. Mr. Coffee DRX5 Water Reservoir Replacement: étape 3, image 1 de 2 Mr. Coffee DRX5 Water Reservoir Replacement: étape 3, image 2 de 2
    • Remove 2 hose clamps from heating element. Remove heating element from tubes.
  4. Mr. Coffee DRX5 Water Reservoir Replacement: étape 4, image 1 de 3 Mr. Coffee DRX5 Water Reservoir Replacement: étape 4, image 2 de 3 Mr. Coffee DRX5 Water Reservoir Replacement: étape 4, image 3 de 3
    • Using a Phillips #1 screwdriver, remove one 10mm screw, and three 11mm screws connecting the reservoir to the base and remove reservoir from the base.
Michael Chhim
Membre depuis le 03/21/17
205 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G2, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S2-G2, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 618
