Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Replacement of the TF6's dust cover is necessary when it is cracked or broken. Replacement dust covers can be obtained from any Mr. Coffee TF series coffeemaker or online at Mr. Coffee's website.
Outils
Aucun outil spécifié.
Pièces
  1. Facing the front of the TF6, gently lift the dust cover along its hinge until it reaches its designed stopping point. Facing the front of the TF6, gently lift the dust cover along its hinge until it reaches its designed stopping point.
    • Facing the front of the TF6, gently lift the dust cover along its hinge until it reaches its designed stopping point.
  2. Orient the retaining bracket upwards (away from the main body of unit). Do not push the retaining bracket beyond its designed range of motion. It may snap if too much force is applied outside its limit.
    • Orient the retaining bracket upwards (away from the main body of unit).
    • Do not push the retaining bracket beyond its designed range of motion. It may snap if too much force is applied outside its limit.
  3. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. With the retaining clip in its released position, pull the spout down towards the filter basket.
    • With the retaining clip in its released position, pull the spout down towards the filter basket.
  5. Carefully detach the dust cover by disengaging the locking pins, starting at one side. Extra force may be required to disengage the dust cover's locking pins. Refrain from applying excessive upward force on the dust cover, as dong so may cause the pins to snap under pressure.
    • Carefully detach the dust cover by disengaging the locking pins, starting at one side.
    • Extra force may be required to disengage the dust cover's locking pins. Refrain from applying excessive upward force on the dust cover, as dong so may cause the pins to snap under pressure.
Follow these steps in reverse order with a new Dust Cover.
Jordan
Membre depuis le 31/01/2014
201 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-18, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-18, Regan Winter 2014
CPSU-REGAN-W14S13G18
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 2
Total : 265
