Aller au contenu principal
Mt. Fury Roadmaster Brake Pad Replacement
Ce dont vous avez besoin
  1. Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: étape 1, image 1 de 2 Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: étape 1, image 2 de 2
    • Locate and remove the dome nut with a 10mm open-end wrench.
  2. Mt. Fury Roadmaster Brake Pad Replacement: étape 2, image 1 de 1
    • Inspect brake pad for wear.
  3. Mt. Fury Roadmaster Brake Pad Replacement: étape 3, image 1 de 1
    • Dome nut (left), lock washer (middle), and brake pad (right).
    • Be sure to save the dome nut and lock washer just in case the replacement brake shoe does not include them.
    • When installing the new brake shoe, make sure it is properly aligned so it is in full contact with the edge of the rim.
To install your new brake shoes, follow these instructions in reverse order.
Monty Dodge Jr
Membre depuis le 01/22/14
669 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 1-40, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 2,061
